Possibility to change the launcher with custom profiles?
I've created 2 custom user profiles based on the ones supplied with the software.
When starting the software I see the launcher and I like that because I can change the settings for the job I want to do. However I only get to choose between the original bricscad profiles and the last one used.
Is there a way to customize or add more profiles to the launcher?
