creating structural axis on non linear solid
Can you create a structural axis on a non linear solid? eg a timber beam that changes its section.
This is a frame I'm working on but I need to allocate a structural axis to each member
  • Hi Chris,
    _bimrecalculateaxis should do it, or just classify it as a member/beam or column. There might be situations that the algorithm does not find it. But I just ran some tests on similar geometry and it was calculated correctly.
