Add my parametric part to Libary
Hi Experts, I would like to add my parametric part to library, Let's say a cuboid with 3 parameters (length,width, height), I have created design table, so I can select the configuration parameter to drive the size of cuboid.
But after I add it to Library, I can only see the length, width and height parameter, how could I use the configuration parameter just like the out-of-box fastener in the library?
Figured out the way to address the issue, set all parameters' exposed property as off except the configuraton parameter before adding into the library.
Hope we could get more support from the forum.0
