Status Bar Icons
How do I make my status bar icons bigger, searched in setting and I can't find a setting....Thank You
  • There is no such a setting in BricsCAD, you can only increase the display scaling setting in Windows Settings to make these icons bigger.
  • Thanks Lyubov, yeah I figured as much. I though there might be, being we cad adjust the size of the Ribbon Icons and such. Changing the scale or resolution of my screen defeats the purpose of a $3,000 monitor. LOL
    Thanks again for replying
    Doug
  • When 4k monitors came out every one wanted one and see problems even now, Windows etc has not kept up.
  • Alanh, Yup, so true. I'll take the trade off however. I recall first using AutoCAd back in 1982 under DOS- OP, 2 monitors, a color and a monochrome for the commands with orange type. We've come a long way. I am a bit surprised however we can adjust the size of the ribbon icons and above. But not that menu. Perhaps because its more or less set it and forget it menu, plus most have shortcuts. Anyway, Thanks for the comment.
