Crosshair Color Change
The crosshairs automatically change to a contrasting color when moved over a bitmap image. In my case dark on a light colored bitmap image.
That's all good but they don't change back and will stay dark on a dark background, sometimes invisible. When this happens manually changing the crosshair color doesn't work. You set the color but the auto contrasting color doesn't change.
Has anyone filed a bug report on this?
1
No, not really.
It is basically the same on macOS.
There are still many contrast issues in GUI.
E.g. I have Bricscad GUI mostly in dark Mode.
While system is set to switch from day to dark mode by time.
So there seem some (uncontrollable) issues when you can see Bricscad's
GUI texts in e.g DynDims or not.
Sometimes I try to switch Bricscad to bright mode when macOS has dark mode
but that does not always help.
It is a bit arbitrarily.
I often wondered why I have 4 lines of options when assigning a Composition
to a Wall. While only 2 were visible.
Until I hovered over the empty rows to find a slightly legible option text with
a 10% contrast ratio, hardly legible, offering more options.
Sometimes I can't even read the DYNDIMS. But there is no real reason or setting
why it is tone in tone or not ....
