Elevation/Section Generation
I am working on the tile laying plan,
I created all wall and floor elevations to create the drawings for the tiler.
In my Sheet layout, I placed this sections/elevations from the BIM model. (using Project Browser/Section and Views)
Most of the sections are working, but some of them do not show the right content.
In my BIM model, I have frozen all the layers containing the sanitary items, other not needed elements, and let just the necessary visible plain walls and floors for the tiles.
You can see the generated section and the showing model do not match.
update model
open model
open model
why is it so? the wall elevations of the same room work , but the floor sections not?
I have also tried to turn off the layers and to hide the entities, but the content of the section does not fit to the content of the 3D model.
The generated wall elevations work fine
what do I miss?
is there a solution? Without deleting and recreating everything.
update model
open model
open model
what do I miss?
Check the Use Layer State property of the BIMsection entity in the model. If On, perhaps the unwanted layers are thawed in that layer state. That's one idea. I, too, run into troublesome layers in BIM sections, especially from blocks.0
Thank You! ScottS
this was the issue! "resaving" the layer state was a little confusing.
But everything worked!0
