How to update a viewport with extra elements
                    I've made some drawings of parts of the drawing by selecting a couple elements and then making views of them. Now i have add some other elements to the drawing. but these are invicible in the viewports (cause i din't select them in the first place). How do you add them to the current viewports
            Do you mean the drawing views, generated by VIEWBASE command? If you used the entire model to generate views and VIEWUPDATEAUTO=1, views are updated automatically after any change of drawing. If VIEWUPDATEAUTO=0, you need to use the VIEWUPDATE command.
But if you selected some entities for generated views, only changes of these entities will be reflected in that views.0
