OLE objects are printed upside down
I can't print excel spreadsheet correctly. Tell me what's the problem. Neither rotating the object itself nor printing upside down helps. What is strange, in v22 they were printed normally.
It is a known bug in V23 that affects certain OLE objects on certain plotters. A fix is planned for one of the upcoming maintenance releases. You may have better luck with a different output device, or you could try tricking the plotter by _DVIEW _TWist 180d to rotate the rest of the drawing to match the upside-down OLE. Alternatively, just use V22 for plotting until the fix is available.0
