[C# Project] Building Project on Build-Server
Hi all,
I am building an app that uses BricscadApp and BricscadDb. This app (C#) should be running on V21, V22, V23, etc.
On the local machine with several installation of BricsCad it works well with '' depending on the BricsCAD version, I choose to compile.
So far so good.
Now I try to integrate this project on our Build-Server, so the Build-Server could build the app in different versions every night.
The Problem: I could not install different Version of BricsCAD on this Build-Server. So, the 'COMReference' will not work.
Has anyone a “best practice” for a solution?
Maybe using 'COMFileReference' instead of 'COMReference' is an option, but I have never used it.
Any solution is welcome! Thank you very much!
Volker
So far so good.
Volker
Not sure how heavily you rely on COM, but you can avoid adding references by using C#’s Dynamic keyword.
Example https://www.theswamp.org/index.php?topic=55916
Hello Nigel,
Thank you very much for your response. Your solution seems really impressive. But I do not think would work for me.
The “only” problem is the step ‘Build-Server’ in the workflow. The app is part of a bigger solution, and it is mandatory, to have an own DLL for every BricsCAD Version.
Volker
Haven’t tried, but you may be able to use Tlbimp.exe, to generate assemblies for each version. Then reference those on your build server.
Thanks a lot for your suggestions.
I tried to work with Tlbimp.exe and in another experiment with 'COMFileReference' instead of 'COMReference'.
In both cases, the build server created the C# project for each desired version.
Unfortunately, the builds created this way do not let me run them with "_NETLOAD".
I get the messages like "Error: The file or assembly "Interop.BricscadApp, Version=22.0.0.0, Culture=neutral, PublicKeyToken=null" or a dependency on it was not found. The system cannot find the specified file."
when you reference the dlls created from Tlbimp.exe, try setting [embed interop types] to false.
you'll need to package those dlls in the same folder as your main assembly.
If that doesn't work, your only choice is to install bricscad on your build server.
edit: or you had [embed interop types] = false and you didn't include the dlls in your package
in this case set [embed interop types] = true.
Yes, I've tried that, but I'm not sure how much that will cause problems in the DLL dependencies later on. Just in case there is a new intermediate version.
I'm afraid I will have to resort to the solution of installing BricsCAD on the server.
Thanks a lot! -
CSLIDs don’t change within intermediate versions, so your safe there.
If you have a server, you can setup virtual machines, one for each version of BricsCAD, and now you can use the build server for automated tests : )
Best of luck
!dan
Hallo Nigel,
That would mean "shooting with cannons at sparrows" as we say in Germany (I don't know the appropriate counterpart in English) for 2 DLLs per version.
But thanks for your suggestions, I see clearer now, and I learned something too.
Volker
Howdy, Stranger!
