BIM MEP Support
Hi All! I am looking for someone to give me a half day, (well paid), to sit in on some BIM work. I am an MEP designer with a truck load of R*vit experience, but want to move to Brics. If you regularly use Brics BIM for MEP, please get in touch.
Are you looking for training for BricsCAD BIM in combination with AX3000? https://www.bricsys.com/en-us/bricscad-for-mep
AX3000 provides training courses, see here
Best regards,
Ruben
Hi Ruben, thanks for your response. I am reluctant to use AX300. Don't get me wrong, it looks like a really interesting piece of kit, but I already have software for sizing services and software for thermal modelling. I would expect that software calling itself BIM would be sufficient for modelling MEP. I haven't found any tutorials etc for MEP via Brics and would be mightily disappointed if it transpires that in actual fact it only serves architects and I need another 3rd party software to do MEP. Do you know if MEP is possible natively in Brics? If I do need an AX3000 licence, will my colleagues also need one?0
BricsCAD BIM natively offers general MEP modeling tools you can use without 3rd party applications. You could start with this tutorial :
https://www.youtube.com/watch?v=nArSqJJN_bw
Can I ask what software you use for sizing and modeling?
Best regards,
Ruben0 -
Thanks Ruben. I have been though a few of the "look how easy this is" videos, but I have immediately run into the sorts of problems that make me nervous about just how capable it is. So my question could have been a little more precise, such as "do people actually use native MEP in Brics as a means for production of PAS192 compliant engineering design and information exchange?" I get it, though. R*vit is not intuitive, I just happen to know the workflow and the common issues when stuff doesn't go into the model properly. I need a 'ground up' lesson to get enough of a handle on how to effectively work with the package, with the Brics workflow.
For sizing, I used to use Hevacomp. Ugly but solid. Now packaged with B*ntley's BIM offer, so I use MEPWorx, (formerly Cymap). It has its own issues, but I can get it to produce reliable and verifiable results. Although MEPWorx also does a small amount of thermal modelling, I use IES for that because it does dynamic simulations, CFD and Radiance. It too has problems and despite having export options for gbxml, ifc and Revit, the results are dreadful.0
