Showing structural Profiles in the Structure Tab
I have a master model which is made up of external components. I am wondering if it is possible to show the member profiles on the structure browser tab that are in the xref component file. It appears to show a handle entity number at the moment (capture2) and I was hoping that this could be the profile size instead.
Thx
Thx
Hi Ian, did you classify the Xref as "BIM Xref", you can do it with the regular "_bimclassify" / other0
Thank you for your reply Piet.
I hadn't classified the xref as you suggested.
I have now done this and the result is still the same.
There are some snapshots attached showing the model and the Xref assemblies, the config of the structure tree settings and the structure tree still showing the handle numbers and not the profile sizes.
Any tips?
thx Ian
