V23 can't change lofted bend subdivisions
Hello,
I'm fairly new to bricscad. I did my 30 day trial on v22 and could change the lofted bend subdivisions easily from the parameters. However, with v23 the only way I can find to change it is through SMDEFAULTLOFTEDBENDNUMBERSAMPLES system variable which works but I'd like to be able to change it like I did in v22.
Hello cranescheduling@boswellcontracting.com,
It still works the same way as in V22, but there is a UI bug in the early versions of V23 that prevented you from changing the number of subdivsions. Have you updated to the latest version yet?
With kind regards,
Robert0 -
No sir, I will. Thank you very much.0
