C# .NET Compiler Error - Could Not Copy File
Hello All! I'm trying to run the C# sample code. Once I added the dlls, and then 2 COM dlls to the project, I thought I was set... However I'm now getting the following last error:
Could not copy the file "C:\Program Files\Bricsys\BricsCAD V20 en_US\ModelerGeometry_20.6_15.tx" because it was not found.
What am I doing wrong?
After I deleted the standard bad references to the BricscadApp and BricscadDB that came with the projection, I added the COM libraries through the Project Menu - Add Reference, which pulls up the Reference Manager dialog. I expanded the "COM" menu on the left, and selected
"BricscadApp Type Library 20.0" and
"BricscadDB Type Library"
Any help is appreciated thank you!
Try changing the dll file property Copy Local to false.
Just a note, I like to have embed itertop types set to true. This eliminates the need to copy the COM DLLs0
