How to Make 3D Mesh Dustbin
in 3D Modeling
Can someone know how to make 3D Mesh Dustbin ?
Similar to this:
https://www.youtube.com/watch?v=CdhaJVS4Li0
Similar to this:
https://www.youtube.com/watch?v=CdhaJVS4Li00
Hello Kamil,
a wire mesh like in your example is often a form of "digital optical illusion".
You don't actually model all the individual wires you "pretend" its a piece of sheet metal.
Phase 1
You model 2 rectangles
Phase 2
You create a loft
Phase 3
The standard material library does not contain a wire mesh model, but im sure you can find something on the internet. So i made my own mesh in paint.
Phase 4
Wet the material and transparancy with the paint image.
Phase 5
This is the result.
For better results you can use rendering software, i use keyshot
Hope this helps,
With kind regards,
Robert
This appears to be intriguing. The 3D design is a fascinating subject. Did you know that 3D scanning and design can be useful in mechanical engineering?0
I think we can take that as a statement.0
