Customise a block to show z attribute
Hi Alij,
what should the final result look like? If you just want text in the xy plane you can use getpoint and create a text only using the X and Y coordinate.
(getpoint [ refPoint ] [ prompt ] )
This function pauses for user input to specify a point, relative to refPoint.
Example
(setq delta (getpoint))
(setq delta (getpoint "\n* Show new location : "))
(setq delta (getpoint '(0 0 0))
(setq delta (getpoint '(0 0 0) "\n* Show new location : ")0 -
Piet thank you. I did manage to figure something out but will look at this for sure0
Look into fields also, move block and z label will change etc.0
Use a field with the Z value of the position of the object0
Just look at mtext and the field option. Can pick the position X Y Z or just 1.0
@Simon1208
the idea is to create a block with attribute,
insert a field in to that attribute that will hold the "BlockPlaceHolder" property of the object.
I attached here 6 screenshots that illustrate the proccess and a sample drawing.
if you change the Z value of the block in the drawing after it is already inserted you need to update it with the UPDATEFIELD command.
hope it helps.0 -
You can automate the sequence in a lisp insert block and attribute has field added. So no need for manual adding field.0
Hi Steve,
I cant actually remember why this was a problem for me now if I am honest as I just flatten it. I think as I was new to this type of block I had some confusion.
Hopefully you are sorted now?0
