Cannot snap to endpoints when placing dimensions
in 2D Drafting
I am trying to dimension between object endpoints but BricsCAD is ignoring endpoints and instead selecting the whole line.
Is there a way to disable this 'smart' behaviour?
What's your OSMODE setting?0
OSMODE is set to 63 and includes endpoints.
Guessing you try to use "Dimension" command . Try using "Linear Dimension" instead.0
Yes I was.Patrik Sparrman said:Guessing you try to use "Dimension" command . Try using "Linear Dimension" instead.
That fixed it, thanks.0
