save ucs orientation in multiple modelspace viewport
in autocad there is a commend "ucsman" this command will be able you to ucs orientation in every modelspace viewport, what command is this in briscad? thanks!
There is no Ucsman command in BricsCAD, but you can create, modify and delete named UCSs through the Drawing Explorer: Tools -> Drawing Explorer -> Coordinate Systems. Short way to launch it is Expucs command and alias 'UC'.
https://help.bricsys.com/document/_commandreference--CMD_expucs/V23/EN_US?id=1650790770400 -
thanks for the awesome information.Lyubov_Osina said:There is no Ucsman command in BricsCAD, but you can create, modify and delete named UCSs through the Drawing Explorer: Tools -> Drawing Explorer -> Coordinate Systems. Short way to launch it is Expucs command and alias 'UC'.
https://myhrkp.online https://flvslogin.online https://pointclickcarecna.online https://theranestlogin.online
