Guided Insert
New to parametric blocks. I am trying to create some parametric blocks with design curves.
My problem is when using the insert block command the "Guided Insert" option is greyed out. Does anyone know if this is a setting? I am using the lite version and do not see anywhere that it is not supported. V22
Thank you,
Dru
Thank you,
Dru
It seems the "Guided Insert" is not available in Lite version, it works in Pro and higher. But it's not mentioned in Help files indeed.0
