ifc export issue
When i export beams, columns, flow segments etc to ifc some of them have as predefined type NOTDEFINED when i open my ifc file in a bim viewer. However some of them don't have this issue and are also imported correctly into revit. What is the reason of the NOTDEFINED classification
Hi Chris,
Could you send us the file you are having trouble with, so we can investigate?
You can also file a support request via https://boa.bricsys.com/protected/support/NewSupportRequest.do?categoryID=115
Best regards0
