Can not Copy (CMD+C) after Migration
ive recently upgraded to a new Mac and transfered all my data from my old mac via migration assistant and everything is working fine but for some reason in Bricscad whenever i try to copy an element via command+C I am getting the following error and am unable to copy/paste. Any idea what i need to do to fix it?
12:26:53: Directory '/var/folders/3x' couldn't be created (error 13: Permission denied)
12:26:53: Failed to create a temporary file name (error 2: No such file or directory)
I would install Bricscad again over it.
For me Migration on Mac worked overall reasonably for most
standard Apps and Settings, but more complex Pro Apps usually
needed reinstalling.
(at least to make hidden things like licensing working)
For Windows reinstalling and resetting paths was mostly needed
for any App, even if you cloned a disk.
BTW,
which macOS.
Did you migrate over more than one generation ?0 -
Hi, just recently I have exactly same issue. after migrating from air (M1) to Pro (M3), suddenly error 2 and error 13 comes when copy .. error states
16:18:59: Directory '/var/folders/8_' couldn't be created (error 13: Permission denied)
16:18:59: Failed to create a temporary file name (error 2: No such file or directory)Migrated was version V24.. I have downloaded and reinstall V25 but same issue ..
Contacted official support, no response yet. Could somebody help?
