Hatch not showing (and priniting...) in 3d Base view but dose in regular MView
Hi.
I have a hatch object in my 3D drawing.
When using the base view command to create printable views, the hatch does not appear, and in a normal MV dose it does (see Capture1.PNG)
I'v also attached the drawing it self (intake2.dwg)
any idea why?...
thanks,
aridzv
any idea why?...
thanks,
aridzv
so it should be. ViewBase views only use solids from the model. they don't work with any 2d graphics. And viewports show the model "as is". If you need to hatch something in the Viewbase, then hatch in paper space. Better yet, use sections.0
