Hole Questions
1.) Is there a way to keep the last entered values I used when creating a hole?
( i.e. properties for a #10 thru hole?)
2.) can I just copy the holes throughout the design, sometimes when I do, they lose the translucent appearance they had after I copy them, is that ok?!?
3.) Is there a way to go thru (2) parts while keeping the top hole portion a CS thru-hole and the hole in the next part to be a threaded hole?
Sorry if this is easy, but I am switching from Fusion 360 as it is way too slow and I want to stay in the ".dwg" format...Thanks in Advance!
