Quad Tabs is Empty Under Workspaces - Solved
                    Trying to get the Quad menu to work.  I the properties part, but not the icons to Edit, Modify, Draw....  I am not sure how to add the menus to it.  I have tried appending it, but there is no Add in there, which is what I seen in the support.  I assume because it's empty, it's done a little differently.  Anybody have any suggestions?
Pic of the CUI menu under Workspaces:
Pic of what it currently looks like:
Pic of what I am looking for, the circled part:
Solved - It appears I was using an old default main CUI file, probably from V22. Needed to update to the new V23 to solve issue.
