Can BricsCAD hide the intersectant line of outer wall?
in BricsCAD BIM
Can BricsCAD hide the intersectant line of outer wall ,when it generate elevation?
Is it really an intersection line (?) or the slabs ?
They look so thick.
(On the other hand, outer edges also look thick)
As in Quick Draw in V23 you have the option to draw slabs between Walls,
like for outer Walls or to draw Walls on top of slab, like for interior Walls.0 -
Thanks for your reply.Michael Mayer said:Is it really an intersection line (?) or the slabs ?
They look so thick.
I've seen some tutorials online, that seem like coplanar intersecting lines can be hidden in elevation or section , but I don't know how to do it.
this is a material property. See screenshot.
