'Specified cast is not valid' error when creating rotated dimension using COM/ActiveX
I am using COM/ActiveX to add a rotated dimension but gives me an error "Specified cast is not valid". The weird thing is the dimension was actually created in the graphical screen but the object/entity was not returned successfully so I can assign a layer, or change its color.
Anyone has experienced this and any suggestion to solve this ?
Here is my code :
Here is my code :
Could be a bug, but if only need to set the layer, you can try making obj a AcadEntity0
Thank you. I tried your suggestion but needed to cast the call as well like :
AcadEntity obj = (AcadEntity)aDoc.AddDimRotated(line1Pt, line2Pt, line3Pt, .707);
in the end it gives me the same error "Specified cast is not valid".
Even simply calling AddDimRotated, it's the same error
aDoc.AddDimRotated(line1Pt, line2Pt, line3Pt, .707);0
