New Ribbon Layer search
Hi! I just turned USENEWRIBBON on and already have an issue. I used to select an object and open the layer Control dropdown menu to change its layer. Normally I tap the first letter of a layer and it goes directly to the correct section I need, but now it does nothing. Will there be a fix in the future?
Probably, it might be more effective to ask this via support request, as a new development or feature request task can't be based on a forum post. I see the mentioned behavior change, but it seems nobody yet reported it.
You can do it here: https://boa.bricsys.com/protected/support/NewSupportRequest.do0
