What are these things and how can I get rid of them?
I copied and pasted some DWG linework from a client's file into a new Bricscad file and now I see these little icons on a part of the drawing (but not everywhere in the drawing). They do not appear in the drawing that the client sent me when I open it in Bricscad. What are they?
I can right-click on one and say "hide all" and they disappear, but then they show up when I select lines so they are not really gone. I have never seen this before.
They seem to be constraints perhaps? When I hover over one it says "coincident" or "tangent". I can delete one at a time in a little X at the corner. But I don't seem to be able to select them all and delete all at once.
Thanks for any insight!
If you go to the parametric tab of the ribbon (if you use the Ribbon) and there is a command called Delete 2d Constraints, this will allow you to select all the constraints and delete them.0
You can also hide them, if you delete them you can't edit the drawing using the parameters anymore.0
