DATAEXTRACTION only of selected objects?
Hi there. I'm new to BricsCAD.
I want to extract data only of my selected 2D-drawing objects into a CSV file, but when I use DATAEXTRACTION I always get all the objects of the whole model space.
Is there a way to only extract data of selected objects?
Thank you
  • Does your version have this button?
  • Yes it does:
    But it still extracts the whole drawing, although it says, that 67 entities are selected.
  • edited April 2023
    It sounds like a bug. In my older version, it extracted only the entities that I selected.
    You should file a support request, sending them the .dwg file and the resulting .csv file, so they can fix the bug.
    Until it's fixed, perhaps you can WBLOCK the selected objects and use DATAEXTRACTION in the new .dwg file.
  • edited April 2023
    With custom lisps much easier to control what is extracted, can use ssget with filters so select only certain objects.
    The data extracted can be sorted counted lengths added up etc.
    Explain what your after what objects to be extracted.
