Get Volume of Water in Tin-Surface
in 3D Modeling
I need to determine the volume of TinSurface up to a certain level of water (see picture).
Can this be done in Bricscad? And how?
Thanks!
Thanks!
Follow the steps:
1. Create a rectangle (red) at the correct elevation representing the boundary area of the water volume
2. Create a flat (blue) TIN surface for the water surface using the TIN command and selecting the rectangle.
3. Use the TINEXTRACT command to produce a Solid between the 2 TIN Surfaces
: TINEXTRACT
Select TIN surface [selection options (?)]:
Extract [Mesh/Solid/Points/Faces/Contours/Border] : S
Enter vertical offset or select [between Surfaces/Elevation] <1.0000>: S
Select second TIN surface [selection options (?)]:
1 entities extracted..........
4. Using the SLICE command slice the solid using 3 non collinear points on the water surface (centers of the 3 red circles)...
The blue solid is the represents the water volume!
You read the water volume in the properties pallete...
You find the dwg file attached
Thank you very much for this very well explained answer. I appreciate the time you invested.0
