Point filter inconsistency
in 2D Drafting
I'm using BricsCAD v23. I have noticed that when i'm using point filter during GRIP_MOVE command, everything works fine. Let's say I typed '.xz and picked some point. From that moment my grip point moves only along Y axis. But when I'm using MOVE command (in edit mode) on some object it doesn't work like that. The object is not restricted - It can be moved freely in every direction.
In BricsCAD 2019 and 2020 it worked the same way for GRIP command mode and EDIT command mode.
Has something changed since earlier releases? Is there some system variable for that?
Best regards,
MK
Best regards,
MK
dear k0k0s,
this might be a bug in V23, could you please fill in a ticket with the support team?
https://boa.bricsys.com/protected/support/NewSupportRequest.do
