Failed to load image
Hello everyone.
I get the error "Failed to load image: Sunnp. bmp" when I start BricsCAD.
This icon was created in AutoCAD; for example, Default. bmp, created under the same conditions, is displayed without any problems.
It is displayed in the original AutoCAD without any problem, and it can be opened in an image processing application such as GIMP without any problem.
What's the problem?
Thank you.
What's the problem?
Thank you.
I guess that the file extension does not match the actual image file format. You can check the first three bytes of the file to determine the format.0
You are correct, when I viewed the file in binary, the file in question started out as a ".PNG".
The normal file was "BM6".
I found the cause.
Thank you very much.
