User parameter as dimension text
I'm new to Bricscad but long time Acad user.
I'm looking for a way to show a user parameter value as the text in a dimension (overriding the actual text dimension). If that's not possible, I'm open to using a standard text or an attribute, I can't seem to locate user parameters in the attribute definition command (ATTDEF).
BricsCAD pro V23.
BricsCAD pro V23.
