Pipeline
Hi everybody,
The easiest way to draw a pipeline on a floor plan.
I thought of a double line but these are not listed in the linetype.
Is there a function to draw double lines? Or does anyone have another idea?
I'm om V21
Greetings
Johan
I'm om V21
Greetings
Johan
A Pline whose Global Width is the pipe's outside diameter?
There's also an Mline command that draws double lines, but I don't think you can fillet the corners.0 -
No fillet radius for mlines, but can do offset multi plines and radius is supported. Lots of lisp out there.
Yes a 300 concrete pipe is actually 380 to outside.0 -
Thanks Anthony and Alanh
I should have posted this for concrete pipes.
; pipe offset for different size pipes
; by Alan H July 2014
; replaces a single line with two lines at correct size of pipe allows for Outside diameter.
(vl-load-com)
;(defun existLinetype (LineTypeName / item loaded lt)
; (setq doc (vla-get-activedocument (vlax-get-acad-object))) ; open database
; (vlax-for item (vla-get-linetypes doc)
; (if (= (strcase (vla-get-name item)) (strcase LineTypeName))
; (setq loaded T)
; (if (= Loaded T)
; (princ "loaded")
; (command "-linetype" "L" LineTypeName "P:\\my\\SUPPORTFILES\\CUSTOM.LIN" "")
;(existLinetype "EX_PIPE250")
(defun pipeoffset (w / ang stpt pt3 pt4 obj whatis)
(setq lt "Divide")
(setq oldsnap (getvar "osmode"))
(setvar "osmode" 0)
(setq obj (entsel "\nPick line"))
(setq objtype (vla-get-objectname (vlax-ename->vla-object (car obj))))
(if (= "AcDbLINE" objtype)
(progn
(alert "You have picked an object which is not a line\nTry Again")
(exit)
(princ "\nLine")
(setq stpt (assoc 10 (entget (car obj))))
(setq stpt (list (nth 1 stpt)(nth 2 stpt)))
(setq endpt (assoc 11 (entget (car obj))))
(setq endpt (list (nth 1 endpt)(nth 2 endpt)))
(setq ang (angle stpt endpt))
(setq pt3 (polar stpt (+ ang (/ pi 2.0)) 1.0))
(setq pt4 (polar stpt (- ang (/ pi 2.0)) 1.0))
(command "offset" w obj pt3 "")
(Command "chprop" "last" "" "LT" lt "")
(command "offset" w obj pt4 "")
(command "Erase" obj "")
(setvar "osmode" oldsnap)
(defun c:P100 ()
(pipeoffset 0.06)
(defun c:P150 ()
(pipeoffset 0.08)
(defun c:P225 ()
(pipeoffset 0.152)
(defun c:P300 ()
(pipeoffset 0.19)
(defun c:P375 ()
(pipeoffset 0.228)
(defun c:P450 ()
(pipeoffset 0.265)
(defun c:P525 ()
(pipeoffset 0.308)
(defun c:P600 ()
(pipeoffset 0.35)
(defun c:P675 ()
(pipeoffset 0.39)
(defun c:P750 ()
(pipeoffset 0.432)
(defun c:P825 ()
(pipeoffset 0.473)
(defun c:P900 ()
(pipeoffset 0.515)
(defun c:P975 ()
(pipeoffset 0.528)
(defun c:P1050 ()
(pipeoffset 0.597)
(defun c:P1125 ()
(pipeoffset 0.6)
(defun c:P1200 ()
(pipeoffset 0.68)
(defun c:P1350 ()
(pipeoffset 0.715)
(princ)
(alert "Enter pipe size at command line eg P300")
(pipeoffset)
