** Error: Automation Error E_FAIL; [IAcadDocument] function [LAYERS] unspecified error**
edited May 2023 in 2D Drafting
Why am I getting this error?
I'm using the Cone11 traffic management operations software on BricsCad Lite, and whenever I try to place a sign on the modelspace I get this notification in the command console.
I have been saving and restarting Brics each time and it reopens and works perfectly (until I begin the next session that I open from my template.
Not sure how to go about remedying this; any help would be greatly appreciated!
Many thanks
  • Did you go back to Cone 11 for help that should be 1st step.
  • I just wondered if anyone knew what type of error this might be. Naturally, upon contacting Cone they were not particularly helpful. Now I feel less helped than before.
  • It may need Bricads Pro not Bricscad Lite. Ask them again.
  • edited May 2023
    I would be inclined to agree with you except I've been using the Lite version for the past 8 months without this error, so I want to believe it's a change I've made in the settings or an issue I can easily address.
  • edited May 2023
    It’s most likely the module, you can test to see if the LAYERS method is available to lite with a simple lisp routine.
    (defun c:doit ()
    (print(setq acadobject (vlax-get-Acad-Object)))
    (print(setq activedocument (vla-get-activedocument acadobject)))
    (print(setq LayerTable (vla-get-layers activedocument)))
    (print(setq theLayer (vla-item LayerTable "0")))
    (vla-put-activelayer activedocument (vla-item LayerTable "0"))
    (print(setq aNewLayer (vla-add LayerTable "NewLayer")))
  • Hi Nigel,
    Thank you for the insight! Am I correct in thinking I simply import that into notepad, save it as a .LSP then drag + drop into BricsCad? What is this code supposed to do exactly? Sorry if I come across as dense, I'm still relatively new to this whole industry!
    Many thanks
    (defun c:doit ()
  • edited May 2023
    Hi Nigel,
    yep, or copy and paste it onto the command line, and type doit
    if you see something like
    VLA-OBJECT IAcadApplication 0000000042FC2190
    VLA-OBJECT IAcadDocument 000000004BFF2798
    VLA-OBJECT IAcadLayers 000000004382EE40
    VLA-OBJECT IAcadLayer 000000004382EEC0
    VLA-OBJECT IAcadLayer 000000004382EF40
    and if you have a new layer named "NewLayer" then IAcadDocument.LAYERS works and it's probably the module that's broken
  • I'll be honest in that I blindly followed your instructions, and can say that I have not found this issue to appear once in the last 3 days!! I think you've solved it, whatever the issue actually was. Thank you so much Nigel as you've saved me a great deal of stress :)
