Gradient color by layer
in 2D Drafting
Dear all,
Is there a way to make the color of a gradient inside a boudary inherited from the layer (1 color gradient By Layer)?
Thanks for your Help
BR
BR
I'm afraid there is no way to do it via existing Gradient options. Maybe it's possible programmatically.0
I eventually switched from gradient to hatch with a solid pattern and it works. Thanks for your help0
Gradient is a type of hatch - no?
Does anyone have trouble with orienting a gradient hatch to anything other than 0o, 90o, 180o, 270o? Choosing any other angle from the dropdown option, or typing another number, has no effect. I have a SR in for this for 15 months, the fault is acknowledged, no fix-date promised - obviously considered low priority. Some more SRs about it might change that.
As a workaround, creating the gradient at 0o then rotating it doesn't work.0
