Problem with a parametric screw
Hey,
I have created a parametric screw. It's attached. The problem is that I want to have a radius on the top. But when I make one, that crashes my parameters. Maybe one of you has a solution to my problem.
That's how it should look for every size:
  • Hello Obas,
    I fixed it for you, when you add the fillet "distance_3" constraint is removed.
    Just re-add it after making the fillet and add a constraint to the radius.
    Seems to be working fine now, If I missed something let me know!
    With kind regards,
    Robert
  • Hey Robert,
    Thank you very much for your solution! It works perfectly.
