Entity Properties - Line - Length and Angle
BeachinItHere
edited May 25 in LISP Codes
Can Length and Angle be acquired from a line entity, or is that not possible? I've been trying without success for awhile.
  • ALANH
    edited May 25
    Yes is the quick answer, have a look at Lee-mac.com for his pline properties lisp it gives an extensive answer.
    The quick and dirty 1 liner copy to command line. To get you started.
    (vla-get-length (vlax-ename->vla-object (car (entsel "Pick pline "))))
    If you explain more what it is your trying to do some one may have a program already done. NOT just get length.
    I'm looking to get the Angle and the Bearing from a property lines to generate a table, to use as a key, full of line curve data.
  • I changed from the idea of the entity being a polyline to just a line.
  • Ok you want a Bearing and distance label. That is easy to do either a line or a pline. Again there is multiple answers to this question, the way to find is like this, Google label bearing and distance Autocad Lisp.
    I would also try Bricscad rather than Autocad. Adding Cad and lisp makes it work.
  • Thank you Alan
Sign In or Register to comment.
Howdy, Stranger!
