BC won't release my plugin when I unload it
I have a .BRX application that I often need to run from the debugger in Visual studio. Sometimes it works for a long period and sometimes it suddenly complains that the file is locked from BricsCAD so it can't build a new version.
So I have BricsCAD started without any plugin loaded. I build and start my application from Visual Studio and in BC I use "appload" and load my application and I can run it. When I'm done I use "appload" and unload it and stops the debug from Visual Studio.
Now I should be able to do the same thing again and sometimes it works but sometimes not so I have to restart BricsCad before I can run my plugin again. It can work for days and when suddenly something must happen and it's not working for days, until it just suddenly start work again. I haven't figured out what is causing it but it must be BC that won't release it even when I do an unload.
This is not a new behavior. It's always been like that.
Usually, this happens because you have some resource still open.
Examples would be using the COM API for another program that hasn’t closed,
or maybe a creating a custom object that’s added to the database.
In the latter case you should lock the app with acrxLockApplication
