Block Attributes - Reorganize order
in 2D Drafting
Dear All,
Is there any way to reorganize order of prompted attributes in a block ?
Thanks for your Help.
Best Regards
Best Regards
What I do is explode the block and then redefine it with the same name, selecting each attribute individually in the order I want their prompts to appear. I'd like to know of an easier way.0
I use the Block Attribute Manager, command "battman".
Select the block from the pulldown at the top of the window, highlight the attribute to reorder and use the up/down arrows to change the order.
