ANNOALLVISIBLE need REGEN to take effect
Hi.
when I change the ANNOALLVISIBLE status,
I need to use REGEN to get the resault...
dose anyone have any idea why?...
thanks,
Ari.
  • Hello,
    I noticed you filled in a support request on the website and you have an answer there. Thank you.
    Have a nice day!
  • edited June 2023
    @patricia.cristescu@hexagon.com
    Hi.
    yes,thanks.
    I first posted it here and after a while I filled out a support request and the support team did reply and is looking into it.
    for the meantime I'm using a lisp to over come this issue - see below:
    defun c:ANNOALLVISIBLE_TOGGLE (/ a)
    (setvar "CMDECHO" 0)
    (setq a (getvar "ANNOALLVISIBLE"))
    (if(= a 0)
    (SETVAR "ANNOALLVISIBLE" 1)
    (SETVAR "ANNOALLVISIBLE" 0)
    (princ (strcat "\nThe value of ANNOALLVISIBLE is:" (vl-princ-to-string a)))
    (vlax-get (vla-get-activedocument (vlax-get-acad-object))
    (if (= (getvar 'cvport) 1)
    (command "REGEN")
    (setvar "CMDECHO" 1)
    (princ)
