Document Tabs disappeared
I am running Bricscad V22. Recently the document tabs have disappeared from the top left hand corner of the drawing window. How do I bring them back?
  • Hello,
    You can bring document tabs back by setting SHOWDOCTABS variable on 1.
    You can find information about this here: https://help.bricsys.com/document/_systemvariablereference--SV_showdoctabs/V23/EN_US?id=16507926951186
  • I've tried SHOWDOCTABS. But it hasn't worked.
  • In Autocad there was a way of toggling between drawings using a keyboard function. Can't remember what it was. Does Bricscad have something similar?
  • CLEANSCREENON/OFF also toggles the tabs
    ctrl+tab
    (which is annoying if you work in 3D and use ctrl, say, to temporarily prioritize face selection mode, then hit tab to selection cycle through entities under the cursor... you inadvertently end up switching to the next document tab!)
