tinedit Remove Boundaries and Remove Breaklines are missing
aridzv
edited July 2023 in 3D Modeling
Hi.
the Remove Boundaries and Remove Breaklines are missing.
when I use tinedit command thos options are missing and when I try to use the shortcut
tinedit -> RO for Remove Boundaries or tinedit -> RB for Remove Breaklines bricscad don't recognize them.
those commands appear in Bricsys Help Center under tinedit command.
I'm using bricscad PRO 23.2.06 (x64)
thanks,
aridzv
  • Hi,
    in V23 you find those commands in the CIVILEXPLORER
    Select the desired TIN in the CIVILEXPLORER
    then under the "Definition" Tab select the Boundary you want to delete and right-click on it to delete or deactivate it
    For the Breaklines -> make a double left-click on the added breaklines and a new window will open where you see all the different Breaklines that have been added
    I suggest you have a look at the new CIVILEXPLORER Panel in the Help Center
    https://help.bricsys.com/document/_panels--PNL_civilexplorer/V23/EN_US?id=166368442310
    The Help Center is a double-edged sword 😅 many explanations for commands are from older Versions (like the tinedit command)
    regards,
    Matthias
  • @Matthias
    Thanks!!
    BTW - I don't have a civil workspace (maybe it is not a part of the PRO version?...),
    so to show and close the civil explorer I've created a simple tool and added it to the civil ribbon...
    And that the help center is a double-edged sword - well,you can say that again... :D
    CIVILEXPLORER only comes with Pro or higher so that shouldn't be the problem
    and the first command in the Civil Toolbar should also be the CIVILEXPLORER if that helps 👍
    could you please check if you have set RUNASLEVEL to 1 or anything different than that?
    if you have a Pro Licence it should be on 1
    if RUNASLEVEL doesn't help you should file a support request then something else is broken 😅
    yeah the Help Center is a nightmare 😂
  • aridzv
    edited July 2023
    it is not there in the civil tab...
    I also didn't find it in the customize interface...
    and also in the workspaces tab I don't have civil workspace.
    I have drafting,drafting (toolbars),modeling,modeling (toolbars),mechanical,BIM and my own customized workspace.
    so my own tool it is.
    actually my RUNASLEVEL value was 5 :D ...
