Each file in a different window
This sounds like your "single-document interface" setting was changed.0
Where can i check it?martin@enco.us said:This sounds like your "single-document interface" setting was changed.
It's the SDI variable (Single-document interface), to check it you can type it in the command line or find it in the Settings dialog. Value 0 - Multiple-drawing interface, 1- Single-drawing interface.0
Thank you. Problem is solvedLyubov_Osina said:It's the SDI variable (Single-document interface), to check it you can type it in the command line or find it in the Settings dialog. Value 0 - Multiple-drawing interface, 1- Single-drawing interface.
