Layer Merge
I recently switched from AutoCAD to BricsCAD and encountered an issue with a Lisp routine that merges layers. This Lisp routine functions properly in AutoCAD, but the equivalent "laymrg" command doesn't seem to work in BricsCAD. I'm wondering if anyone else has experienced this problem and if there are any known solutions or workarounds available. I would appreciate any insights or alternatives.
There is a Merge Layers option in BricsCAD. If you select one or several Layers on Layers panel or in Drawing Explorer and press the right mouse button, you can find the "Merge to..." option in the appeared context menu. When you click it, 'Merge Layers' dialog is opened, where you can choose a target layer where the selected layers will be merged to.0
