need help to add list to lisp
in LISP Codes
Hi.
I found a lisp (see attached) that joins lines,polylines and arc.
I need help with getting this lisp to do it only for items on specipic layers - this is the list I need the lisp to work by.
I inserted the list (named "Datalist") in to the lisp already,
and I need help with getting the lisp to use it and join only the objects of those layers.
I also Attached a sample file.
thanks,
aridzv.
thanks,
aridzv.
Looks like you could change your SSGET call to the following:
(setq sel (ssget "_:L" '((0 . "ARC,LINE,LWPOLYLINE")(-4 . "<OR")(8 . "P_DN*")(8 . "P_Later*")(-4 . "OR>"))))
This adds an OR option to SSGET only allowing layers beginning with P_DN* or P_Later* to be selected. Using wild cards avoids the need to create an exhaustive list of layer names.
For more info on using SSGET, I suggest that you check out this article on Lee Mac's site
http://www.lee-mac.com/ssget.html
BricsCAD V23 Ultimate
CAD Concepts0 -
Hello aridzv,
As an alternative to Jason's code, you can also combine the entry in group code 8 with commas:(setq sel (ssget "_:L" (list '(0 . "ARC,LINE,LWPOLYLINE") (cons 8 (apply 'strcat (mapcar '(lambda(X) (strcat X ",") ) (mapcar ' car DataList)) ) ))))
=> (cons 8 "P_Laterl,P_DN16-4,P_DN16-6,.....")
This should work, but I hav'nt tested it.
regards
Jörn0 -
