Indeed, there is no equivalent for MLEDIT command but a feature request task is created. I'm not sure if this will be implemented in the near future.
Meanwhile there is a free BcadTools application in our catalog, which provides MLEDIT command:
boa.bricsys.com/applications/a/?bcadtools-freeware-a335-al528
You can use this free plug-in in the meantime, as a workaround.
Editing juctions and adding additional vertices for Multilines
A migrant from AutoCAD here. I'm testing out the multiline function in BricsCAD, but I've noticed there doesn't seems to be an equivalent to Autocad's MLEDIT command, which allows me to modify existing Multilines, such as adding additional vertices, or creating open T-junctions, like the below:
I've searched this on the official help page, and also Googled elsewhere, but I can't seem to find this.
2
You can use this free plug-in in the meantime, as a workaround.-1 -
It would be nice to have MLEDIT tools natively supported in BricsCAD (even BricsCAD Lite) as a nice selling point over AutoCAD LT as loading third-party .brx tools in BricsCAD Lite isn't supported.
Hi @brynmor530 , we have a feature request task about MLEDIT command in BricsCAD. It would be useful to create a feature request to add a value to the task.
I just installed it, and for every single one of the Multiline Edit tools it says this function is not yet implemented. Not very helpful! Has this happened, have I installed an old version somehow??
