3D constraints for AutoCAD Objects
I tried to use constraints using at XYZ axis, but is not possible, only can I use XY axis.
How to use constraints at XYZ axis using Lines? I mean using constraints or 3D constraints.
Hello jtm, i'm a bit confused what you are trying to do.
There is no such thing as a xyz axis.
You have:
1. X-axis
2. Y-axis
3. Z-axis
4. XY-Plane
5. YZ-Plane
6. XZ-Plane
Bricscad 3D constraints only use the Planes (4,5,6).
If you want to constrain an axis to a plane you could use a fixed line as an axis.
Could you tell a little more what your goal is? Perhaps we could be more helpfull then.
Regards Robert,1 -
Could you share a PDF guide to learn parametric 3D in Bricscad?
You may want to look at the Youtube channel of BricsCAD, that will be easier to follow than reading some text for most people.
Or try this page
Alternatively you can download the product documentation (manual) from this page
1
