selection set by effective name for both regular blocks and parametric blocks (*U Type)
as a resault of a need in a lisp,
I had to make a selection set of blocks by their effective name,
because the regular way whould have taken a parametric/dynamic/anonymous blocks by their *U name and not by their effective (insert) name.
I found this old post that solve that (very big for me) problem:
replace that line in code:
to that:
hope it will help,
aridzv.
; Function to create a selection set of standard & dynamic blocks
; That have the same Effective name
(defun BlockSSET (blname / sset ss-dyn num ent effname)
(vl-load-com) ; ensure that ActiveX is loaded.
(if (not (setq sset (ssget "X" (list (cons 2 blname))))) ; Select block with standard method. This will also capture dynamic blocks in their default state.
(setq sset (ssadd)) ; if nothing is found then create and empty selection set
(if (setq ss-dyn (ssget "X" (list (cons 2 "`*U*")))) ; select all anonymous blocks. this will also capture any dynamic blocks that have been worked with
(progn ; If anonymous blocks found, check for the given effective name
(setq num 0) ; zero counter
(repeat (sslength ss-dyn) ; repeat for the number of objects in the selection set
(setq ent (ssname ss-dyn num)) ; find the entity name
(setq effname (vla-get-EffectiveName (vlax-ename->vla-object ent))) ; Find the EffectiveName of the block
(if (= blname effname) ; if the blockname matches the effective name
(ssadd ent sset) ; then add it to the original selection set
); end if
(setq num (1+ num)) ; Increment the counter by one
; return the gathered selection set
sset
with one small change:replace that line in code:
(setq effname (vla-get-EffectiveName (vlax-ename->vla-object ent))) ; Find the EffectiveName of the blockto that:
(setq effname (getpropertyvalue ent "EffectiveName~Native")) ; Find the EffectiveName of the blockhope it will help,
aridzv.
