Call BricsCAD through web application
Can i make a web application call Bricscad and insert blocks change attributes etc?
Is there any code sample? Any tutorial?
Best regards
Best regards
Not Bricscad but Autocad Accorconsole could be used on a dwg possibly as its driven at the OS level, there is some discussion about a Bricscad equivalent.
Other way may be at looking at the start up of a program and load a script as part of the start up, look at your icon desktop properties.
"C:\Program Files\Bricsys\BricsCAD V20 en_US\bricscad.exe" need to add start script here
Yep found it but that is your task Google start up switches Bricscad.0
