Software data management
Hi there
What software do you use for data management with BricsCAD? I am very new user and looking for an alternative to Autodesk Vault.
Thanks in advance.
Thanks in advance.
Did you have a look at Bricsys 24/7?
One that I have seen being used often is ProjectWise from Bentley (Microstation) but there are plenty of systems out there and it depends on your needs which ones are suitable (or overkill) for your purposes and budget.0 -
Thank you for your reply.RSW said:Did you have a look at Bricsys 24/7?
As I correctly understood, 24/7 its cloud based solution. I don't like it, I need a local solution.
We are a small company, so the budget is also small.
Thank you for your advice on ProjectWise, I will have a look.0 -
We had a system where Iused to work we could find a dwg from 1999, it used an Access database. I am not sure if still supported. It had lots of input like charges against the dwg. So maybe look at Access.0
Thank You for Reply.
I will think about it.0
